CD3215 U3100 USB-C port controller CD3215C00
$18.99
ZA2-CD3215C00
- Buy 4 for $13.99 each and save 26%
CD3215C00 U3100 USB-C port controller
The CD3215C00 is the USB-C port controller that negotiates 20v from the USB-C charger.
BE AWARE: CD3215B03 will NOT work in place of a CD3215C00. Most are selling CD3215B03 which will never allow you to get 20v on the charger. This is the real CD3215C00!
Also be aware you need PP3V3_G3H to be present before you can blame the chip. If you do not have PP3V3_G3H on your board, you might have an ISL9239 problem where ISL9239 is not sending the enable to the PP3V3_G3H regilator to turn it on.
If a SINGLE CD3215 on the board is defective, NONE OF THE OTHERS WILL WORK!
We're not refunding you if
- This doesn't fix your problem.
- You burn the chip soldering it.
- You break something.
Enjoy!
| Compatible boards | 820-00244, 820-00875, 820-00281, 820-00840, 820-00239, 820-00923, 820-00850, 820-01041, 820-01521 |
