Quick 861DW Hot Air Rework Station
Only %1 left
quick-861dw
If you want to buy an 861DW, we no longer sell it - buy it on Amazon. Quick now gives lower prices to other vendors, so we no longer sell the 861DW. If you wish to buy one, get it with free shipping on Amazon.
The 861DW comes with three nozzles and outperforms Hakko & Weller hot air stations in interface, features, and raw heating power. This is Louis Rossmann's current pick for a hot air station regardless of price.
Price should go back down by early December, our apologies.
Affordable hot air without compromise.
Years ago, spending less than $650 on hot air meant receiving a station that lasted six months. Or, receiving a station that wasn't powerful enough to remove chipsets from multilayer areas with large ground planes. Enter 2017, where cheap hot air is powerful and accurate enough to perform sensitive jobs at a low price point; click here for an example of the Quick in action!
Quick, powerful heating & airflow. Solder SMCs, RAM ICs, touch ICs effortlessly.
An FR-810 can be seen taking over TWICE the amount of time that the 861DW took to remove large chipsets from a multilayer PCB here. This station dwarfs the Hakko FR-810 and Weller WHA900 in terms of time to heat up, and overall power. I have tried cheaper stations where, after 10 minutes, it couldn't remove an ISL6259, much less a CPU MOSFET. This hot air station is powerful enough to meet most needs even when working with ICs that have a large heatsink pad soldered to a large ground plane. Further, it heats up nearly instantly after turning it on.
ONE CLICK temperature & air adjustments.
Adjusting temperature or airflow on the Hakko FR-810 is worse than programming a 1985 VCR. Even the $1600+ JBC JT-A station requires multiple button taps if you want to change air vs. heat. The Quick 861DW allows you to make changes to temperature or airflow with one click of a button.
ONE CLICK profile loading.
Do you have specific airflow & temperature settings you use regularly for different boards? You can store three presets and recall them with one click. The embedded oval around the buttons means you don't even have to take your eyes out of the microscope to find the buttons and click them. It is ergonomically friendly.
A sincere thank you from Rossmann Repair for supporting us with your purchase!
Purchasing this station from us helps support the business that brought you over 600 component level repair videos as well as the board repair forum with thousands of publicly available answers & solutions. Thank you so much for your patronage and we sincerely hope you enjoy this station!
You're reviewing:Quick 861DW Hot Air Rework Station
