LiveU Solo PRO HDMI with 2 Modem kits + belt - For Complete Live Streaming
$2,300.00
rossmann-liveu-solo-pro
This includes the LiveU Solo PRO unit (the HDMI version), two LiveU modem kits, the case, and the charger. It's used and it's tested working; the livestreams below came off this unit.
Bonding is what you're buying this for. When you pay LiveU to activate the two modems, the unit automatically chooses the two best carriers in your area and sends the signal out over both modems to give you the best possible stream. Keep in mind the modems only work with LiveU's service; their two-modem unlimited data plan was $295 a month when I checked in July 2026.
See the quality for yourself. These two livestreams were done on this unit:
If the player says playback is disabled, watch it on YouTube.
What is included:
  • LiveU Solo PRO encoder, HDMI version (HDMI in, Ethernet, WiFi, microSD slot)
  • 2 LiveU USB modem kits
  • LiveU belt case that holds the unit & both modems
  • USB-C charger (the unit needs at least 45W)
About the wear: the case has a hole I put in it so I could hook the unit up, with the modem holders in the case, to the 1/4-20 mount on the top of my camera. There are also some holes cut in the netting to fit charging & ethernet cables through the waist belt. It's all in the photos.
I'm selling it because I got a Sony PDT-FP1, which is more lightweight.
You're reviewing:LiveU Solo PRO HDMI with 2 Modem kits + belt - For Complete Live Streaming
