U4001 NXP 610A3B tristar iPhone 7 & 7+ charging IC
$3.49
F4-NXP-610A3B
NXP 610A3B Tristar IC for: iPhone 7, 7+ as U4001. Also compatible with 6S, 6S+, SE, iPhone 5S, iPhone 5C. It will NOT work in an iPhone 5! This IC talks to the charger before allowing it to charge the phone, and often causes slow charging, no charging, or death after being plugged into a fake charger.
This Tristar IC talks to the charger before allowing it to charge the phone, and often causes slow charging, no charging, or death after being plugged into a fake charger. U4001 on the iPhone 7 and 7+.
This is compatible with iPhone 7, 7+. You may receive a different model/revision than what is listed, but what you receive will be compatible.
| Compatible boards | iPhone 7, iPhone 7+ |
