NXP 1610A3 U4500 tristar USB logic & charging IC
*Discontinued item*
This item is no longer used, it has been superseded by NXP 610A3B click here!
NXP 610A3B is a direct replacement for this chip!
NXP 1610A3. Tristar IC for: iPhone SE, 6S, 6S+, U4500. You can use this in place of 1610A1 and 1610A2 and it’ll work just fine. This IC talks to the charger before allowing it to charge the phone, and often causes slow charging, no charging, or death after being plugged into a fake charger.
*Discontinued item*
This Tristar IC talks to the charger before allowing it to charge the phone, and often causes slow charging, no charging, or death after being plugged into a fake charger.
U4500 on iPhone SE/6S/6S+
This works in place of the 1610a1 & 1610a2 so feel free to use it in older phones which use the 1610a1 & 1610a2 IC. Revision received may be different than what is pictured.
| Compatible boards | iPhone 5S, iPhone 5C, iPhone 6, iPhone 6+, iPhone 6S, iPhone 6S+, iPhone SE |
