NXP 1610 A2 tristar U1700/U3500 logic & charging IC
$3.49
F4-NXP-1610-A2
*Discontinued item*
This item is no longer used, it has been superseded by NXP 610A3B click here!
NXP 610A3B is a direct replacement for this chip!
NXP 1610A2. Tristar IC for: iPhone 6, 6+, U1700, iPad Air 2 U3500
*Discontinued item*
This Tristar IC talks to the charger before allowing it to charge the phone, and often causes slow charging, no charging, or death after being plugged into a fake charger. NXP 1610A2.
U1700 on the iPhone 6/6+
U3500 on the iPad Air
You should probably buy the 1610A3 instead as it is compatible and less likely to fail. In fact, if you buy this chip, we might just send you an A3 for your own good.
Compatible boards iPhone 6, iPhone 6+, iPad Air 2
You're reviewing:NXP 1610 A2 tristar U1700/U3500 logic & charging IC
