Circuit Specialists PPS2116A USB Programmable Power Supply 0-32VDC 0-5A
$149.00
cs-power-supply
For streamers and video recorders, this power supply is for you. Its voltage/amperage show up on software that you implement into OBS so it shows up on-screen! This is essentially the same thing as the cheaper power supply I have listed besides the ability to see it on-screen.
This power supply allows you to inject voltage into a power rail of a mainboard to locate a short circuit. You can also power an iPhone or a Macbook with this power supply if you have the proper adapter cable to hook up to it.
Click link to purchase from our Amazon affiliate that has this item in stock right now!
You're reviewing:Circuit Specialists PPS2116A USB Programmable Power Supply 0-32VDC 0-5A
