Atten ST-862D Hot Air Rework Station 120VAC-New
$275.00
atten-862
This is a 120VAC system! It comes with bent angled nozzles instead of straight nozzles.
We have used/scratch & dent stations available at a discount here:  https://store.rossmanngroup.com/atten-862-scratch-and-dent.html
Buy used scratch & dent models at a discount by clicking here
SHIPS SAME DAY AS OF 04/11/2025 FROM AUSTIN TEXAS!
Cheapest price in the United States, 2 year warranty & support from Rossmann Group, same day shipping from Texas
Affordable hot air without compromise.
Years ago, spending less than $650 on hot air meant receiving a station that lasted six months. Quick came out with the 861DW that was half the price with twice the power of many stations on the market. Atten has added features, lowered pricing, and improved quality of AC filtering - the lights flicker less with this than they do with a Quick!
Quick, powerful heating & airflow. Solder SMCs, RAM ICs, touch ICs effortlessly.
This station seems to equal the power of the Quick 861DW & best the abilities of any Hakko or Weller we have used at much higher price points. rge ground plane. Further, it heats up nearly instantly after turning it on.
Three angled, bent nozzles INCLUDED with every station!
We include 3 bent nozzles with each station - no need to hunt down bent nozzles elsewhere. You get three nozzles for reworking smaller ICs up to SMCs & RAM chips! This does not include straight nozzles.
ONE CLICK temperature & air adjustments.
Adjusting temperature or airflow on the Hakko FR-810 is worse than programming a 1985 VCR. Even the $1600+ JBC JT-A station requires multiple button taps if you want to change air vs. heat. The Atten ST-862D allows you to make changes to temperature or airflow with one click of a button.
ONE CLICK profile loading.
Do you have specific airflow & temperature settings you use regularly for different boards? You can store three presets and recall them with one click. The embedded oval around the buttons means you don't even have to take your eyes out of the microscope to find the buttons and click them. It is ergonomically friendly.
A sincere thank you from Rossmann Repair for supporting us with your purchase!
Purchasing this station from us helps support the business that brought you over 600 component level repair videos as well as the board repair forum with thousands of publicly available answers & solutions. THANK YOU!
You're reviewing:Atten ST-862D Hot Air Rework Station 120VAC-New
