USB-C Amp Meter
This is the best USB-C Amp Meter we have found so far for its price. It has a good feature list for a simple meter.
The reasons why we like it:
1) No splash screen, the instant you apply power to this it displays the voltage and amp usage.
2) Flip the screen with a double tap of the button. No more reading up-side-down!
3) All the information, at a glance, on one screen. No cycling between readings.
Screen images NOT simulated, that is what the screen looks like. Everything you need to know, Voltage, Amperage, Direction of current flow. Some memory functions: Time charging and how many milliamp hours have been drawn. And it does the math for you and tells you how much wattage your using.
Best thing about this meter, it's robust! Louis has not broken one yet!
| Compatible boards | 820-00239, 820-00281, 820-00840, 820-00045, 820-00244, 820-00928 |
