iPhone battery wire adapter cable for DC power supply
This cable has a button that allows you to prompt the phone to boot with a single button!
This plugs into a bench power supply and allows you to turn the phone on with the click of a button. No more looking for a power flex or a charge flex with a USB cable to prompt the phone to turn on while on the bench!
How to use:
Plug one end of the cable into your phone motherboard, and the other end into the iPower Red box. Plug the iPower Red box into your power supply. There is one button to send PSU voltage to the phone, and another to prompt the phone to turn on. Do NOT PLUG THE USB CABLES THAT COME WITH THE PHONE INTO A USB PORT ON A COMPUTER OR CHARGER!
This is the highest quality iPhone-DC power supply cable on the market!
This cable will properly report to the phone its temperature so that it stays on.
This cable has a much more natural feel to the battery flexes - it stays plugged in, and is as easy to plug in as a normal iPhone battery.
Its durable construction means it will last longer.
Plug your phone board directly into a DC power supply!
This cable allows you to plug your DC power supply, rather than a battery, into an iPhone motherboard. This way you do not need to keep a bunch of batteries on your desk. Also, you can see how much amperage the phone is drawing, which is crucial for troubleshooting.
This connects to almost everything.
- iPhone 5
- iPhone 5C
- iPhone 5S
- iPhone SE
- iPhone 6
- iPhone 6+
- iPhone 6S
- iPhone 6S+
- iPhone 7
- iPhone 7+
- iPhone 8
- iPhone 8+
- iPhone X
| Compatible boards | iPhone 5, iPhone 5S, iPhone 5C, iPhone 6, iPhone 6+, iPhone 6S, iPhone 6S+, iPhone 7, iPhone 7+, iPhone 8, iPhone 8+, iPhone X |
