821-1480 A1278 Hard Drive Cable for Macbook Pro
$14.91
AB3-821-1480-a1278-hdd-cable
This hard drive cable is for 13" Macbook Pros from 2012, but can be used in older models as well with a little jerry-rigging. These machines were manufactured until late 2015.
If your machine is running ruthlessly slow or not recognizing hard drives even with a known working drive, your issue is often the hard drive cable. This is one of the only laptops on planet earth known to have HDD cable failures.
No used cables here!
These are the good cables, not cables ripped from other machines.
| Compatible boards | 820-3115 |
