Quick NK2127 12.7mm bent angled nozzle
$16.99
AB18-NK2127-quick-nozzle
12.7mm bent angled nozzle for Quick 861DW
Bent nozzles allow working under a microscope.
When you use a microscope, you are forced to use your hot air at an angle. This makes it more difficult to aim hot air directly on the chip or component you are trying to heat. With our bent nozzles, you can use your 861DW handpiece with a microscope and still aim your heat directly onto the chip.
12.7 mm in size
This is a large nozzle, more suited for larger chips like the SMC or the PMIC.
You're reviewing:Quick NK2127 12.7mm bent angled nozzle
