Mechanic IX5 iPhone Logic Board Heater
$44.99
AB14-Mechanic-IX5-INCLUDING-PLUG
This heating plate will heat the logic board enough to separate the upper and lower parts.
Plug and Play! Super easy to use!
Heating plate for iPhone X series logic boards (X, XS, XS MAX) This heating plate will heat the logic board enough to separate the upper and lower parts.
Bonding temperature of 185 degrees celsius.
Anti-slip mats on the bottom with built in cooling holes.
Accurate and controlled temperature output technology for anti-damage purposes.
Compatible boards X, XS, XS MAX
You're reviewing:Mechanic IX5 iPhone Logic Board Heater
