Quick NK2064 6.4mm bent angled nozzle
$19.99
AB10-NK2064-quick-nozzle
6.4mm bent angled nozzle for Quick 861DW
Bent nozzles allow working under a microscope.
When you use a microscope, you are forced to use your hot air at an angle. This makes it more difficult to aim hot air directly on the chip or component you are trying to heat. With our bent nozzles, you can use your 861DW handpiece with a microscope and still aim your heat directly onto the chip.
6.4mm in size
This is an average, run of the mill sized nozzle.
You're reviewing:Quick NK2064 6.4mm bent angled nozzle
