My Cart:
0 item(s) - $0.00
You have no items in your shopping cart.
0
Rossmann Repair Group Inc
Probes, wires, supplies
Multimeters, jumper wire, gloves & more.
Items 11 to 20 of 39 total
Page:
  1. 1
  2. 2
  3. 3
  4. 4
  1.  Wiha Torx T5 ESD Safe Screwdriver
    Wiha Torx T5 ESD Safe Screwdriver.
    Click link to purchase from our Amazon affiliate that has this item in stock right now!
    $12.09
  2. Wiha Torx T6 ESD Safe Screwdriver
    Wiha Torx T6 ESD Safe Screwdriver.
    $12.09
  3. Wiha Torx T8 ESD Safe Screwdriver
    Wiha Torx T8 ESD Safe Screwdriver.
    $8.07
  4. Wera Phillips #0 ESD Safe Screwdriver
    Wera Phillips #0 ESD Safe Screwdriver.
    $9.93
  5. Wiha Phillips #000 ESD Safe Screwdriver
    Wiha Phillips #000 ESD Safe Screwdriver.
    $8.63
  6. Sim Card Tray Removal Pin For IPhone/Samsung
    Sim Card Tray Removal Pin for iPhone/Samsung
    $1.50
  7. Branson EC Electronic Solution, 1 Quart for Ultrasonic Cleaners
    Click to purchase from our affiliate on Amazon even if we are out of stock on our site!
    This is the liquid we use in our ultrasonic cleaner. Mix 103 milliliters of branson EC with 1 gallon of distilled water for a perfect cleaning solution.
    $23.75
  8. Branson EC Electronic Solution, 1 Gallon For Ultrasonic Cleaners
    Branson EC Electronic Solution, 1 Gallon for Ultrasonic Cleaners
    $56.65
  9. Tekpower TP3005T Bench Power Supply 0-30V 0-5A
    Tekpower TP3005T Bench power supply 0-30V 0-5A
    This power supply allows you to inject voltage into a power rail of a mainboard to locate a short circuit. You can also power an iPhone or a Macbook with this power supply if you have the proper adapter cable to hook up to it.
    $79.99
  10. MG Chemicals Super Cold Spray, 285g (10 Oz) Aerosol Can
    This freeze spray allows you to easily locate heated up areas on the board. Spray the board prior to injecting voltage, and watch it freeze up. Turn the power on and wherever the board initially defrosts is your problem area.
    $12.67
Page:
  1. 1
  2. 2
  3. 3
  4. 4
